Absolutely gutted!
Just finished and had to move an old matress out. There must have been a tiny imperfection in the finishing of the top surface and the material of the matress 'picked it up'.
The result is a 100mm long lift which maxes out at about 20mm wide.
I have bonded it with PVA and knocked it back in to place as best as possible. I then sat some weight on it, but it is still a little raised and the tip of the splinter in missing leaving a 20mm long by 5mm wide groove at the leading edge.
I really need to rub it back level and fill the leading edge with something so that it doesn't get caught again.
Any tips on how best to achieve a good end result??
The floor is Engineered Riviera oak with an oiled finish from source wood floors. http://www.sourcewoodfloors.co.uk/shop/riviera-oak-oiled.html
Any help would be greatly recieved.
Huw
Huw
