Excavating slab for garden room
3 Nov 2020
Hi I'm new to this forum so please be kind.
I currently have planning permission for a garden room in the back of my garden measuring externally 6m x 7m. I am looking to do most of the work myself, even tho I'm a fairly confident and good all round do it yourselfer I just have a couple of questions.
Basically I'm planning to dig footings 600mm wide and approx 800mm -1m deep depending on the soil, above dpc it will be 100mm block 100mm cavity and 100mm block inside wall on the plans were doing engineering bricks on the outside to dpc hight which needs to be a minimum of 150mm above ground level.
My question is because I'm doing a concrete slab floor, which will be made up of 150mm hardcore 50mm sand binding 100mm celotex and 100mm concrete my dpc will be 400mm above ground level approx 5-6 engineering blocks, this will keep the external wall dpc level with the floor and the internal dpc does this sound correct or is there a better way of doing this?? Overall I will have a 400mm high set of steps to get into the building...
Kind regards adam
You dig out the internal floor area to required height from dpc level, so if your brick to dpc is 150mm above ground level,you reduce inside area to 400mm below your dpc,and then bring your finished floor level to dpc. you could reduce sand to 20mm ish to help a little.
Thank you for your reply Charlie its kind obvious now. No doubt I will have some more questions on the way...
