HELP! WORCESTER 24i JUNIOR DROPPING SYSTEM PRESSURE IN DAYS!
13 Nov 2005
Sussex
HI! CAN ANYONE HELP I HAVE A JUNIOR 24i WORCESTER AND IT SEEMS THAT WHEN YOU PUT THE CENTRAL HEATING ON AFTER ABOUT THREE DAYS THE SYSTEM PRESSURE GAUGE SEEMS LOWER THAN 1.5 BAR. WHEN THE WATER TAPE GOES ON THE PRESSURE SEEMS TO GO UP A BIT. THE INFO I WAS GIVEN WAS TO USE THE KEY AND FILL THE TANK SO IT GOES BACK TOO 1.5 BAR.IS IT THE WATER PRESSURE OR DO I NEED PARTS HELP THANKS DICKY:cool:
You may need a pressure vessel or perhaps a PRV or it could be that you have a leak. No one here will tell you anything more unless you give us more information and MOST IMPORTANTLY TURN YOUR CAPS LOCK OFF!!!!!
