HND6515 Hoover dishwasher
17 Jun 2011
Derbyshire
The dishwasher is not heating the water anymore, and it just washes for about 15 minutes then stops and starts beeping
Bleeping & flashing lights are the machine's way of saying it has a problem. Since you know it doesn't heat you know what the problem is.
What do you want to do about it?
my HND6515 Hoover dishwasher is not heating up so I want to know how to get at the element, and thermostat so I can check them, then if they are ok I what other parts could it be.
No heat issues can be due to a faulty element, NTC/thermostat, wiring, pressure switch, or pcb. The element is mounted vertically at the rear of the machine, access to test it is via a cover at the lower centre (rear). There is a sensor on the sump, to get to that you need to lie the machine on its back & remove the baseplate.
I haven't had chance to check my dishwasher yet, but what are the items what can stop it heating up.
