Honeywell F2- 9421 Diverter Valve
9 Nov 2011
Invernesshire
I hope someone can give me an idea about fixing this valve.
My CH stopped working yesterday but HW worked as normal. Boiler seems fine (only 3 years old). Heard it might be a faulty diverter valve so, with boiler power off, I moved the little levers from auto to manual. There was resistance and they whirred back to auto. Its an S plan system so I put the CH valve lever to manual and latched it. Switched on, and radiators heated up (although not as hot as usual).
The valve is a Honeywell F2 - 9421 and I believe its possible to just replace faulty parts rather than the whole thing.
Can anyone indicate what part could be faulty and how to replace it?
Thanks for any help!
Just looked at the less obvious side of the valve - it's a V4043H. The F2 - 9421 is maybe not its model number. Sorry!
Probably find the motor inside has failed. Don't waste your time buying a cheap copy motor...they often last only 12 months.
