Hallo.Need some information for pricing.A large shed is being built in my garden and i need a fuse board in it for sockets lighting and supply for a hot tub.
10mm swa is being run to the shed
#1-Theres a 63a Buiders supply with 50a mcb already there/unused feed by meter tails from henly block,is this ok to feed the new non-rcd CU in the shed in 10mm swa?
Hot tub=16a
Lighting=3a max
Sockets=5-10a
#2-should the CU in shed be rcd protected and swa protected by switchfuse fed by meter tails instead of rcd?
Hope this makes sense thanks!!
___________________________________
Lynda, moderator
please read theforum rules
Hot tub=16a
Lighting=3a max
Sockets=5-10a
Lynda, moderator
