Hot Water ain't very hot
24 Apr 2004
Hi
Moved into a flat a while ago which has storage heaters and off peak electricity I guess servicing the hot water tank which is a Santon Premier Unvented Hot Water System model type TP120E capacity 120 litres. Problem is the water isn't very hot when used and therefore hardly lasts warm for a shower. Is there a theromostat or something I can adjust on it, or does anyone have any ideas please. I don't need cold showers yet!
Thanks!
I'd bet a shilling that under the blob(s) on the side where the wires go in, are thermostats you could twiddle. Turn the power off while you're delving.
:D Spot on chris - dial under cover was on hot so turned half way to very hot - great - no more cold showers - thanks a lot I owe you a shilling - Ian
