Hello all,
Have been scooting around the forum a while now and have usually come across the answer in a search but now I have a problem that, whilst I'm pretty sure on, would be grateful for some reassurance/assistance.
The system in question is a back boiler (Unsure of the make) located on ground floor, F&E tank in the loft and cylinder,pump and programmer on the first floor.
I drained the first floor and removed one radiator, capped off, refilled and bled the system. Switched the system back on and now when the programmer calls for hot water, one or two of the first floor radiators get hot.
I'm pretty sure it's a sticking three port valve as with the power off you can move the lever to B position and then to A. BUT, when the programmer asks the three port valve to call for water, the lever doesn't make it all the way across and rests somewhere around the "manual"setting.
Any help/reassurance would be greatly appreciated.
Regards,
Dubnut
Regards,
Dubnut
