I have a problem which has shown up recently with the water heating or lack of it.
The system I have is a pressurised combined water and central heating system. It comprises a standard ch pump which feeds 11 radiators, a second pump and controller which feeds an underfloor room heater and a water cylinder. All of this is supplied by a Potterton boiler. The underfloor heating was supplied in the March 2009 and after a few teething problems (the plumber connected the feed to the second pump to the wrong side of the existing pump which prevented it triggering the new pump when required) I think it was all ok from here but I cannot be sure that I ever ran the whole system together (rads-underfloor and water heat). Assuming that this is OK then why does it now take even with central heating turned off nearly 12 hours to heat the water? (It used to take about an hour and was pretty noisy in the process)
I suspect the mid position valve which may not be opening fully and restricting the flow through the hot water cylinder. The reason I suspect this is that the boiler comes on for a while (no call is been made by the central heating or underfloor) but it only stays on for a short while (a few minutes ) .
Any ideas , comments or suggestions on what I should do are very welcome.
regards
Graham
regards
Graham
