Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Hi can anyone help please. I'm trying to fit a bath. I've turned the hot water off from the gate valve but it's still dripping any idea what the problem could be and how do I fix it. Many thanks
The problem is the gate valve. Some people fit them to act as service valves, but they are really not suitable for this. They are often used where the flow of water would be restricted by using a service valve, such as on a supply to a shower. Best solution is to fit a temporary stop end until your'e ready to reconnect to the bath tap.
