I have a gravity fed back boiler set up, but there is no thermostat on the hot water side, so as you can imagine the hot water is scolding hot when its run.
There isn't a thermostat on the central heating side either, just controlled via a Honeywell ST7100 programme timer.
The cylinder is directly above the boiler (well, up in the bedroom), so i would imagine that the fitting should be quite easy to do.
What sort of price should I be looking at for fitting a hot water thermostat?
Also, a rough price for fitting an RF type room thermostat for the central heating?
If anyone is local to Doncaster and fancies having a go.... let me know
