Hot water will only dribble out of all hot taps in my house
15 Mar 2007
Hello!,
Hot water will only dribble out of all the hot taps in my house, it takes hours to run a bath! The Kitchen tap is the best running at double dribble strenght so i have to wash my hair at the kitchen sink!
The cold is fine on all taps.
I live in a bungalow that has oil fired central heating , with some small bore pipe and some normal size, but the water has been fine for a year ,we have tried pressure because we thought it may be an air leak but no help. dont know what else to do.? We would be gratfull for any help
Ann
Is your hot water system connected to a drunk with prostate problems or is it connected to a boiler of some sort. Would be easier to help diagnose if we knew which! :roll:
JohnD said:
Do you have a hot water cylinder? is it fed from a cold tank in the loft? How high is this above the taps? Tell us what size the pipes are.
Also, read this http://www.diynot.com/forums/viewtopic.php?t=6026
and provide the info please
and read this http://wiki.diynot.com/plumbing[/QUOTE]
Hi, Thanks for replying.....Yes it is connected to a hot water cylinder, it is fed from cold tank in loft, its about 15 ft above the taps. Which pipes? The bathroom pipes are normal standard I think. Sorry I'm quite helpless with this sort of thing.
Best Ann
If you have a mixer tap put the palm of your hand over the end of the tap, open the hot first then the cold slowly, do this for 30 second bursts then close both taps then open the hot. Does this solve the problem ?
