Hotpoint Dishwasher FDW60
18 Dec 2011
Durham
Our FDW60 keeps coming up with the flashing Eco light code. I keep draining having to drain the over flow and have checked the output pump (stripped, cleaned and re installed), all the joins pipe connectionns seem to be ok.
Any common leak issues with the FDW60?
I have checked the lower sray arm and replaced the washer on the top spray arm.
Is the salt lid nut loose or the one under the bottom spray arm. Circulation pumps leak as well.
Hi, many thanks for the reply.
Both nuts are tight, I will have a look at the recirculation pump.
