Hotpoint WMBF 944 outlet pipe water valve.
Hi folks, I am normally resident in the AV section, but I have a washing machine plumbing issue that is foxing me.
The above washer has a valve in the end of the outlet hose. Without something to press and hold the valve open then the washer can't drain.
The fitting just off the U bend that the outlet valve connects to is effectively "capped" when the tube is attached. This is because this water valve has a flat head and it is large enough to cap the sink fitting.
Can this valve be removed or is there a special fitting under the sink that holds it open without being blocked?
