How do I safely remove a double socket
1 Nov 2005
I've moved a TV and a few other bits from oe end of my lounge to the other and now I want ot remove the 2 old double sockets which are not be used. They are on a ring so I need to keep the wires conneted.
Questions are,
1. Is it safe to remove the socket and connect the wires with a suitable 30amp connection strip (plastic with brass connectors) or do I need a more heavy duty MK 30amp type J/B?
2. Is it safe to then fill / plaster over the J/B or do I have to cover it with a blanking plate?
Any help or previous experience much appreciated.
Connector strip is fine, and no you can't fill it, you'll have to cover it with a blanking plate
In which case you might as well just leave it alone. Can never have too many sockets.
Well - I guess if your wall looks like this, you can...
[EDIT]Image replaced due to link rot[/EDIT]
