How long does it take boss white to go off?
Discussion in 'Plumbing and Central Heating' started by Golfball, 1 Apr 2008.
  1. Golfball
    Golfball
    7 Jul 2005
    12
    Thanks Received:
    Country:
    ie - when can i refill my system
  2. Sponsored Links
  3. twgas
    twgas
    26 Oct 2007
    4,900
    Thanks Received:
    426
    Kent
    Country:
    if you only used boss white it will leak, you need hemp with boss white, or just use ptfe tape, no need to wait for it to go off
  4. Golfball
    Golfball
    7 Jul 2005
    12
    Thanks Received:
    Country:
    Used ptfe the last time and i was still gettin weeps on 28mm compression fittings :rolleyes:
    Is there any particular way i should be applying the ptfe?
    I know the direction etc but should i cover the olive or place some on the pipe water side of the olive?
    Yours novicely obviously
  5. twgas
    twgas
    26 Oct 2007
    4,900
    Thanks Received:
    426
    Kent
    Country:
    sorry, thought you meant on threads :oops:
    a smear of boss white around olive will be ok to fill straight away, over the course of a few years it will harden and make seperating the joint difficult but not impossible.
  6. kevplumb
    kevplumb
    18 May 2004
    23,712
    Thanks Received:
    925
    depends where i get sent
    Country:
    as soon as you like ;)
  7. Sponsored Links
  8. Golfball
    Golfball
    7 Jul 2005
    12
    Thanks Received:
    Country:
    Thanks guys :D - I have it smeared round the olives
    Just seems still very soft to fill ?
  9. Goldspoon
    Goldspoon
    20 Jan 2008
    916
    Thanks Received:
    33
    Anglesey
    Country:
    Do you use plenty of PTFE? I used to not use enough but was told by somebody to use 5 or 6 thicknesses (i.e. 5 or 6 times around a thread or olive). Works for me really well now in 99%+ cases.
  10. stardanny
    stardanny
    14 Nov 2007
    1,660
    Thanks Received:
    256
    Buckinghamshire
    Country:
  11. seco services
    seco services
    3 Dec 2007
    15,701
    Thanks Received:
    1,260
    Essex
    Country:
    don't you just love em when they wrap miles of it around radiator olives and you've got to pick it all off when it leaks.
    [​IMG]
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
