How much to replace a Suuprima 60 pcb (whatever that is)?
30 May 2005
Kent
From you helpful people on here I have deduced that, like many before me my Suprima 60 boiler has a fault that is a common one - it often cuts out when it has heated the water. If I call out a CORGI chap to replace the pcb (what's that stand for?) - how much will that cost me roughly? And can these fine CORGI folk quickly establish what the problem is (just to be certain)?
cheers P.P.
__________________
moderator
please note 9
Cor blimey guvnor thats gonna cost ya, see to get to the pcb we have to remove the laffymoneyconverter then the oofamacallit, then using double jointed fingerswe can remove the f****gbo****in sharpycutting fingery thing specialy sharpened for such maintenance, cost wise ooooooooooooooooofffffffffffffffff about 50p for the pcb plus a billion percent markup for the manufacturer another million percent added on to save africa's debt, so if you go to Goldman &Sachs about 4£million , your local corgi on a good day about £225.00
Identifying the fault can apparently be difficult for some people.
Deciding that the PCB has failed is largely as a result of checking that all the other devices in the boiler are operating correctly.
Although I change several pcbs every year on this model I have come across two faulty ignition leads and one faulty venturi.
The simple unreliable pcb has now been replaced with a more expensive one at about £150 which is promised to be more reliable.
Tony Glazier
