How to form a piece of stainless steel for boat?
3 Jul 2013
Cumbria
Are longer threaded stainless eyes available? If so rather than try and get a thin bit if stainless you could carve a block of hardwood and fully encase it in fiberglass in the boat and run the bolts through it.
6 Aug 2022
To get a pattern of the shape, could you use thin copper tubes (or other easily malleable material), set at defined vertical distances apart, bent to imitate the horizontal contours.
22 Jul 2016
I have used the very strong aluminium catering/disposable roasting dish type things to form a curved pattern. It holds a pattern well .
if you wanted to get really creative, somebody could cast a curved piece from a template.
or a grinder / power file on a very thick slab of stainless and then profile it?
no idea how hard grinding a slab of stainless might be.
30 Dec 2018
I understand from your thinking to just bolt a steel plate, the only way to contour would be to hammer/tap into place.
Stainless steel very quickly work hardens, making it impossible to hammer into shape.
