    Dismiss Notice
How to remove metal insert from plastic Pipe
Discussion in 'Plumbing and Central Heating' started by Mmark, 29 Apr 2016.
  1. Mmark
    Mmark
    8 Mar 2011
    141
    Thanks Received:
    London
    Country:
    I have a plastic pipe used in a brass elbow compression fitting. The things leaking, so i've had to remove and replace but I don't have much leeway and cannot damage the pipe in anyway - the other side is embedded in concrete, under a tiled path and would be prohibitive to have to fully replace.
    I got the olive off, but I cannot seem to get the metal insert out. Any ideas? Is there a special tool for this?
    Mark
  2. Sponsored Links
  3. Dan Robinson
    Dan Robinson
    1 Jul 2007
    56,034
    Thanks Received:
    9,420
    Hertfordshire & London
    Country:
    Hep inserts have barbs, so if you have them then you're screwed.
    Pictures please.
  4. Mmark
    Mmark
    8 Mar 2011
    141
    Thanks Received:
    London
    Country:
    I found this article, suggested using an expanding rawbolt. Tried it, worked great. Luckily the insert was smooth.
    Mark
  5. Tipper
    Tipper
    1 Dec 2008
    1,145
    Thanks Received:
    103
    Devon
    Country:
    I've always yanked them out a little with a pair of pliers then prised them out with a screwdriver.
    Only the newer Hep2O sleeves have barbs, the older ones don't. Both come out OK.
  6. sooey
    sooey
    10 May 2006
    11,971
    Thanks Received:
    889
    Merseyside
    Country:
    Why did you have to replace the insert if you'd got the olive off?
  7. Sponsored Links
  8. Agile
    Agile
    26 Jun 2004
    64,017
    Thanks Received:
    4,591
    London
    Country:
    I was wondering that too.
    In fact I wondered how it was leaking and thinking that a little PTFE usually solve small leaks!
  9. SandyLyon
    SandyLyon
    21 Oct 2012
    625
    Thanks Received:
    140
    Lancashire
    Country:
    Since you're got the olive off replace it with a copper one (softer than brass) if needed a bit of PTFE tape as Agile says.
    Don't use jointing paste with plastic and make sure you put the insert back into the plastic pipe.
  10. DP
    DP
    10 Dec 2003
    14,785
    Thanks Received:
    3,251
    Glasgow
    Country:
    Wire with a hook will remove many insets, others like speed fit and ones DR mentioned might need to be cut out if you cannot find replacements
    Cut the pipe with a cutter instead of saw (rough saw cut often not square so seal may be compromised or plastic barbs etc causing leak)
    In past have used PTFE with mixed results
  11. dilalio
    dilalio
    20 Mar 2009
    7,891
    Thanks Received:
    1,278
    Potters Bar
    Country:
    I usually try sticking a speedfit pushfit stop end on the pipe and then take it off again as the inserts often come out inside the stopend!
  12. Mmark
    Mmark
    8 Mar 2011
    141
    Thanks Received:
    London
    Country:
    Thanks all.
    I'm just going to replace everything except for the plastic pipe that cannot be moved, the parts are not expensive. The copper pipe is oxidised and covered in bonding, and I read that inserts can be damaged, so best to replace. Maybe they could just be re-used, but the parts where cheap, so I thought it simpler to do it, and make sure it was right.
    I have to stick with a brass elbow as the plaster space is small and a plastic elbow will protrude otherwise.
    Definitely going with a brass olive on the copper side, that was something I learnt yesterday - thanks for confirming this is a good idea. I will stick with a copper olive on the plastic side.
    I have some paste for the copper side - it seems the world is split 50/50 on paste vs ptfe tape.
    Was just reading today about whether paste can or cannot be used on the plastic side, thanks for confirming it cannot, will need to look into what I can use that side, maybe just ptfe for that side.
    Fingers crossed
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
