icon combi boiler
B
BOB.DOLE
icon combi boiler, problem if hot water tap is turned on no hot water, but if heating turned on then hot tap water gets warm for a while
but with hot tap on only nothing happens , no pump,fan, etc.
combi is not an ideal icos, its a icon
can this be the diaphragme or diverter valve
26 Jun 2004
London
Diverter valve.
Not so easy to get at !!!
Tony
30 Jan 2006
Dorset
Just changed a diverter valve on one of these this week, but is was just diaphragm. B'stard of a job, cant get a spanner on half the nuts. So just do the 'phragm & you'll be ok. Just to really nark me an unsoldered joint behind the units gave up while I was f'ing and going & got my toes wet. Lovelly job!
B
BOB.DOLE
Agile said:
Diverter valve.
Tony
where can i get litriture on these boilers,
think i will pass the job on.
8 Oct 2003
Bristol
They are glow worms (4704712), also badged as hermann as mark says.
25 Aug 2003
Surrey
thanks mate, cant be many in surrey I have yet to come across one
6 Jun 2004
London
There are a couple of different boilers called 'Ikon' or 'Icon'.
The 23T and 28T were sold (exclusively?) through Travis Perkins.
You'll know if you've got one of these because (AFAIR) it's virtually impossible to change the diverter valve diaphragm in place.
My strategy was to remove the gas valve for access and then dismantle the diverter itself in the middle, taking out the right-hand half and leaving the left side in place, connected to the pump etc. (That is, if i'mthinking of the right boiler!)
24 Nov 2004
Merseyside
the travis perkins ikon was a gw ultimate. or was that just their brand name.
24 Jul 2003
London
Hmm, diaph looks OK in the manual. Is this it? - I've not met one.
If anyone needs MI let me know.
Whenever I split dv's in situ the shuttle bits drop apart... :evil:
11 Jun 2005
Best to take the whole lot out the divertor has a push fit into the dhw h/exch so that has to come off. Will need to replace all the washers as it will leak.Worse boiler they make to work on
28 Jun 2005
BOB ........again you have made an Iconic Post :LOL:
4 Aug 2005
Yorkshire
useful to know about I'll tell Yorkshire customs not to let any into God's own county.
