got a call from mother,her boiler would'nt fire up,but when i got there the problem was that there was no lights or display showing on the front panel.
so checked fuses all ok,dropped the main pcb,there was power going through the on off switch,which came from and returned to the pcb,found a fuse at the back of the pcb panel this was also ok.with a voltage on both sides.
so is the main pcb goosed?,is there anything else that could have caused it to fail?any other checks i can try?
i priced a new one and it was £140 quid,so i don't want to replace it and find it blows again or it's not the problem. thanks
