HI there,
Our boiler has just decided to go on the blink, bt with an ideal should expect this, having had 2 pcb's in 5 years (one after only 1 month of having it!). Its showing LF alternate flashing.
I have cleaned out the condensate trap, refilled and refitted. I have also earthed out the ignition electrode and that fires up whenever the cycle increases the fan speed during its 3 light up attempts. I have also removed the white pipe on the gas valve and found it dry.
After I reset it displays a "3" on the control and runs through its cycle before going to the fault code. Any advice would be gratefully received.
All the best
Jamie
All the best
Jamie
