I have had one of these boilers fitted for about 5 years. Last year my CH system started banging when the boiler shuts off. It is fitted to a fully pumped vented system and was initially installed at the same time as my old gravity system was converted to fully pumped. The installers did not fit a bypass in the system and until recently this was not a problem. When the banging started I fitted a bypass in the form of a gate valve but have changed this to a proper bypass valve. However the banging goes on each time the boiler shuts off. I am surprised that the boiler manual makes no mention of a pump over run; it is possible build in a pump over run even though the boiler does not include a facility for one?
I clean / flush / inhibit my system annually and can find no other reason why it should bang on shut off; it seems the obvious cause is the pump shutting off preventing continued circulation of the very hot water in the boiler heat exchanger.
