C
chrissib
Hi I have a very old boiler which has been very reliable up to now.
Now I cannot light the pilot light.
The Gas control valve has a big grey button/plunger on top, which in the past I have just held down, and hit the igniter button to re-light the pilot. But whereas before I could hear and smell a gas flow when the grey button is pressed, now there is silence, and no smell, and no flame.
My question for starters, is this button is purely mechanical. That is when pressed, it opens the valve and gas should flow, is this correct. Or could there be anything else in the body of the gas valve which would stop the flow, even if the grey button is pressed?
I am quite willing to buy another valve, if I am convinced this is the problem. Before you ask, there is definitely gas getting to the boiler. This has been tested by shutting the valve just prior to the Gas valve assembly, disconnecting the union before the Gas valve, and momentarily opening up the gas. Sure enough a hiss, and a smell.
So any of you experts out there can answer my question, I would be grateful.
Chrisb
Chrisb
