If fitting a drinking water fountain is a double check valve required?
Discussion in 'Plumbing and Central Heating' started by CAESAR32, 10 Jul 2017.
  1. CAESAR32
    CAESAR32
    9 Aug 2009
    314
    Thanks Received:
    2
    Blackpool
    Country:
    So either fit one of them or turn the iso right down then?
  2. CAESAR32
    CAESAR32
    9 Aug 2009
    314
    Thanks Received:
    2
    Blackpool
    Country:
  3. Sponsored Links
  4. CAESAR32
    CAESAR32
    9 Aug 2009
    314
    Thanks Received:
    2
    Blackpool
    Country:
    The service valve turned down abit do a similar job?
  5. CAESAR32
    CAESAR32
    9 Aug 2009
    314
    Thanks Received:
    2
    Blackpool
    Country:
    Looked online some blubber taps you can adjust the flow on the tap. not sure if you can on the one I fit was no instructions. the ones online it says you remove the top and adjust a screw on top of the cartridge. If you could on this tap would of thought they would provide instructions or is it standard for blubber taps?
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
