Indesit W123 flashes 4 times
25 May 2008
Cambridgeshire
Hi
The control module on my Indesit W123 recently went bang and a couple of small triacs failed along with some pcb tracks. The track carried mains to the switch as far as I can see.
Repaired the module as best I can (electronics engineer) and can't see any more failed components.
Washer now powers up, pump runs, tries to fill, then goes off with led flashing 4 times and timer clicks round.
If I select spin it does spin but stops near the end. Have checked heater element,ntc,pressure switch,motor brushes,inlet valves(continuity) as best I can !
Am guessing the module processor is u/s but would welcome advice as these aren't cheap !
Many thanks
