Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
If there is no sign that water has flooded the conditioner chamber it is likely that the water valve that allows water to flow into the conditioner chamber has failed. The cold water valve assembly usually consists of a couple of valves manufactured as a unit. One part directs water to soap container while another part delivers water to the conditioner. Usually easily replaced by a competent DIY person.
If this is one of the Indesit models with the rotary program switch on the top right of the machine and the soap / conditioner tray on the top left of the machine, then there is a problem with the operating linkage between to two, due to bad design. Basically the linkage can disengage inside the machine meaning that if it does, all water goes only through the soap tray and to fix it, the linkage has to be put back in place. Then of course, you need to fix it so that the same doesn't happen again. Is this your design of machine ?
Had exactly the same problem with mine. The linkage from the timer to the tray assembly was fine. What this linkage does is to move the water jet and align it with pathways in the tray unit to direct the water to the various compartments. Over time the pathways had become rather gunged up with that horrible black sludgy stuff. I removed the complete assembly and separated the top section which screws on and cleaned the whole thing out. Worked fine after that. The water inlet above the conditioner tray is just one very small hole so that's the first thing that will get blocked. Hope this helps.
Paul
