Hi
I have just moved both tanks in the loft, using push fit pipe and fittings (any comments). I refilled both tanks but discovered a small leek from the radiator feed outlet. I have drained the rad tank again but can't drain the hot water tank. I opened the hot taps yesterday whilst draining down, before which I turned off the water supply and the timers for the heating, I haven't touched the boiler, nor have i had the heating on. I'm unsure around the pumps and boiler so don't want to fiddle without any advice that you may kindly offer.
Regards Kev
Regards Kev
