Hi all,
New poster to the forum but have learned lots on this site for various DIY tasks over the past 12 months or so.
I've seen other similar posts regarding my query and also I note the Part P requirements (which I have a question about below).
- I am removing an electric oven and gas hob from the kitchen of a new house we have purchased (Gas safe engineer will have to do hob) and replacing with a new fan oven and induction hob. The current wiring set up is as follows - 32a MCB to cooker switch with additional socket. When the switch is on, the oven switches on. There is also a plug socket underneath the counter which is fed from the switch unit and only live when the main oven switch is on - this currently only supplies hob ignition.
- The new hob is 7.4 kw max. It requires 32A MCB.
- The new oven is 2.3kw max and states it requires a minimum 13a fuse.
I do not need the socket on the cooker switch unit. Is it possible and most importantly safe, to run the new hob from the existing oven switch (6mm cable?) and the oven from the plug socket?
It does however state that BOTH oven and hob need to be hard wired so I am unsure of the oven.
Also, does this fall outside of part p and will I require a certified spark to do the work if, I can wire up from the existing circuit. Thanks in advance and I hope to get some positive responses.
Jon
Jon
