INHIBITOR SUITABLE FOR BAXI & OTHER ADVICE PLEASE.
17 Jan 2008
Newcastle upon Tyne
Thanks in advance for all replies...just want to ask if anyone can recommend a rust inhibitor suitable for a baxi combi 105HE?
Also...
- my central heating system has been drained down approx 4 times over the last year 3 times its been just re-filled with water. Would this cause long term damage? ( KEPT FORGETTING ABOUT INHIBITOR )
- can i add inhibitor now through the top bleed valve of a smallish towel radiator?
- just fitted a new kitchen RAD, 2 days ago which is starting to show very minor signs of rust where the tails go into the RAD. Should i be concerned?
Thanks.
you don't get rust inhibitors.
yes you should have added an inhibitor every time it was drained.
yes you can add it now.
if rust is showing a joint is leaking & if its showing on a new rad take it back & buy a quality product.
Thanks for the replies fellas...much appreciated. Inhibitor has been added replaced the rad which the shop exchange due to a fault. Cheers
