Hiya Guys
Is my first time here so need help!!!!
I am currently floorboarding my attic and decided to change the lighting arrangements. Am proposing to install 2 flourecent tube lights and wire them up to a twin switch.
Both lights have existing on/off switches located on the casing.
The power supply into the attic is coming from one of the ceiling roses in a downstairs room. (Live, Neutral & Earth).
I need to connect each light to the twin switch, preferably separately to each switch, whilst still retaining the ability to switch on/off the lights from the casings.
When viewing the back of the twin switch, the following can be seen:
First switch - top row (first two holes belong to "1", second two holes belong to "L")....second row (two holes belong to "2")
Second switch beside it has the exact same configuration.
HOW DO I MAKE THE CONNECTIONS?????
If you need a diagram, I can email you one!!! CHEERS!!!
