Current set up: I have a comsumer unit with 6 x mcbs 2 x 6A, 1 x 16A & 3 x 32A. The consumer unit says "Total Load 60A".
Question 1: Could someone explain what Total Load means? It suggests in this casew that if I have the shower and cooker on at the same time regardless of anything else, I will be overloading! surely not!?
One of the 32A mcbs is dedicated to the existing shower. I have bought a 40A mcb to repalce it per the shower installation instructions. Wired between the meter and the CU I have some form of 100A circuit breaker with the words "ASN 100R 100A MEM".
Question 2: Can anyone explain what this is... RCB maybe??
The shower installation instructions say I need an RCB between the cu and the shower (or as part of the cu) I have no spare spaces in the cu.
Question 3: With my existing set up am I ok to just change the mcb from 32A to 40A or do I still need the rcd?
In a few months time I will be converting a workshop to a shower room so I will need a second dedicated circuit for the second shower. Would changing the existing cu to a larger one be the best answer in the long term? If so can I get mcbs/rcds that simply plug into the new cu??
I have some experience of changing/moving/installing both lighting/power but I am not confident enough to go ahead with this without consulting you experts out there! Advice will be gratefully received
