We just had a woodburner installed. Previous fire was a gas fire with back boiler, and chimney had a liner suitable for gas fire (thin aluminium, I think). Fitter advised pukka stainless steel liner. I deliberated about this at great length as I thought brick chimney would be OK, and save me £300 for the liner. In the end decided to go with liner. Result?
Definitely have liner installed. The efficiency of the burner relies on getting heat into the flue asap to assist drawing, especially on dank, airless days. The liner will heat up much more quickly than a brick/stone chimney and you will benefit from easy lighting, and getting heat out of the burner within minutes. Also, easier to clean and maintain, and no risk whatever of smoke leaking through any hidden cracks in the brickwork.
