Installing switched downlights in the kitchen
4 Dec 2006
Manchester
Hi!
I am about to replace the kitchen, and taking the opportunity to install halogen under-lights whilst there is the opportunity.
I am unable to utilise the current kitchen lighting supply since the switch is too far away.
I do however, have existing switched 13A wall sockets. Is there some way of making use of these to provide a switched supply to the downlights?
yes.
plug them in :lol:
or use a switched FCU, see the sticky or wiki
Even if you were to utilise the lighting circuit, the switch would not be the place to take a feed from :wink: (clue: a lack of neutrals would be quite prohibitive) :lol:
Apolgies, let me clarify - i don't want to te up the 2 x 2 gang sockets currently available. These would be used for fridge, kettle, toaster etc. Also i don't want wires on display where aviodable.
I was thinking of installing a switch next to to current sockets, running a feed from them to the socket, then up the wall to a point just above the wall units and mounting a surface mounted un-switched socket.
You should also note that installing a fused spur unit in a kitchen is notifiable to LABC under part p of the building regs, on the other hand, plug together link lights which plug into an existing socket are afaik not notifiable.
Hum. Cheers for that - stopped me in my tracks.
An electrician may do the spur for less than the notification fee. Worth a try, IMO. Just do all the donkey work for him, it shouldnt take a good spark more than an hour.
Took me and an apprentice 6 hours to wire 2no. UCLs recently.
I mustn't be a good spark :cry:
ricicle said:
Stop quoting times Crafty, every job is diffrent :wink:
I did tell the OP to do all the donkey work too! By this i meant chasing plaster and backbox recesses, maybe even fixing the backboxes to the wall. Simply running a bit of 2.5 up some capping, wiring each end to an accessory, fixing to wall and testing the circuit is not a big job. Maybe an hour is optimistic, depending on whether any problems are found. :wink:
Whyyyyyyyyyyyyyyyy? Were you using SWA? or MICC? Metal conduit? :lol:
You said it, matey!! :wink:
No, you're wrong. Only last month I was in Pizza Hut in Halifax and the people on the next table were discussing a hunky, efficient spark called Rob who did a socket job for them.
Oh, sorry, can't have been you, they said hunky...
:lol:
