insulation and sleeve
10 May 2006
Hi all.
A friend's back boiler has packed up and he wants to replace it with a combi boiler. I will do all the pipe work for him and a corgi engineer will install the boiler and connect up the gas pipe to it. He wants to position the boiler in the kitchen, upon recommendation of the gas man, where i will have to dig a channel in the solid floor to allow the pipes ( flow, return, cw, hw and the gas bloke will run the gas one) to reach to the boiler. My questions are:
1) How wide has the channel got to be to accommodate the five pipes ie; distance between pipes.
2) how deep has the channel got to be to accommodate the insulation around the pipes and the sleeve.
3) how thick has the insulation got to be and what sort of insulation do i have to use
4) diameter of sleeve and what material
5)what to use to seal their ends
6) do you know a quicker option but not a cowboy one.
Thank you for your time.
A 200 x 50 duct with a 12mm ply lid should do the job.
For lagging I would look at 19mm wall but 13mm would do if space is tight.
Hi doitall and thanks 4 your replay.
In that case do i still need to sleeve the pipes or do i only need to sleeve them if i wanted to cover them with concrete? Also,if i do not cover them in concrete do i have to use clips so that the pipes do not move? Thanks again.
You should clip them in a duct.
The hot and cold has to be accessible, so if you wanted to screed them in you would need pipe in conduit, and the cold would need to be away from any heat.
You can buy sectional floor ducking in plastic or galv.
Thanks a lot
