internal door repair
17 Aug 2007
Buckinghamshire
Solid timber internal panel door (about 15yr old) has a small split running across the centre of the hinge attachment point. Screws obviously do not now stay where intended so its either repair or replace. Any ideas on repair methods that are likely to be permanent as I don't want it coming down on my 2yr old (cause of damage - don't ask).
At the moment all I can think of is glue and clamp.
Shot of damage here -
heeeelllooo rjibbotson and welcome :D :D :D :D
assuming its a solid door
lay the door on the floor hinge edge facing up gently tap in a wood chisel to open the split without spreading it by further delamination
fill with glue remove chisel re-insert chisel then remove to pump glue in clamp up tight
find out what screws fit flush in the hinges if its no7s your restricted to around 1.5" so pilot drill out the first 0.75" with a 3mm drill in each hole
if its a no8s then drill out the first 1" with a 4mm drill and use no 8 by2 1/4" screws
if its a hollow panel door you will only have around 25 to 35mm to work with so glue and hope is your only choice just make sure all the screw is fully threaded
big-all : Many thanks for that :D - I had wondered how to get the glue in sufficiently deeply. Will give it a try this weekend.
