- Joined
- 8 Oct 2021
- Messages
- 19
- Reaction score
- 1
- Country
Installing insulation on no-fines wall which is neither plumb or level due to the softness of the block. I originally intended to foam celotex foil backed onto it, finishing with 12.5 normal plasterboard and twistfix through both layers into the block.
The room is very small box room so studding out isn't ideal and no cavity so d&d is out as well. What would be the recommendation? Fill and straighten beforehand or adhesive foam, straighten/plumb and fill gaps behind with more foam?
