Looking for an intruder alarm which only requires two sensors, one at each entrance (front and back door) and recommendations?
It's not for me but a friend has requested one. Not something I normally get involved in.hi there,
is there a reason you only want to use sensors and no contacts?
happy to recommend some systems to you but quite often there are other option.
Point noted and I did mention this with regards to the windows, but for some reason they are intent on having door contacts only.its worth keeping in mind the main entry exit route will have a time delay before setting of the alarm.
if you use only contacts, you are reliant on someone breaking in the door. if the come through a window they can freely walk around.
