    Dismiss Notice
Is my fireplace safe?
Discussion in 'Building' started by Dit, 20 Sep 2009.
  1. Dit
    Dit
    12 Dec 2006
    38
    Thanks Received:
    Gloucestershire
    Country:
    Hi!
    I've removed the plywood board covering a fireplace, in order to replace it with plasterboard so it can be skimmed. Lo and behold, dodgy looking bricks! They can be jiggled slightly but I'm reluctant to interfere too much.
    In your expert opinion, should I worry about them, and if so should they be replaced or mortared in place?
    Many thanks for all help received.
    Tim
  2. Sponsored Links
  3. ^woody^
    ^woody^
    3 Sep 2006
    33,583
    Thanks Received:
    4,563
    West Mids
    Country:
    It's nothing.
    Take the loose brick out or gob it up to stop it dropping later
    Remember to fit a vent if boarding the fireplace up
  4. cmother1
    cmother1
    31 May 2007
    1,375
    Thanks Received:
    41
    Surrey
    Country:
    If you're intending to cover the opening I think I'd brick it up from the bottom with lightweight blocks. It looks a bit too dodgy to leave, so it's either that or put in a small lintel. The span is very small so even a thick piece of flat steel would probably do.
    You can wedge up loose brickwork with pieces of slate (the real stuff), before pointing.
    If you do brick up remember to leave a hole for a vent.
  5. ^woody^
    ^woody^
    3 Sep 2006
    33,583
    Thanks Received:
    4,563
    West Mids
    Country:
    It's not even two bricks wide, and all the bricks above it are self supporting, so no need to go overboard with extra supports and unecessary work
  6. rottie007
    rottie007
    25 Oct 2008
    39
    Thanks Received:
    Worcestershire
    Country:
    i had the same problem withmy bedroom fireplace openings.. I can only presume the original fireplaces had the lintels built into them somehow..
  7. Dit
    Dit
    12 Dec 2006
    38
    Thanks Received:
    Gloucestershire
    Country:
    You guys are brilliant, thank you for the advice. I'm going to use plasterboard to cover the opening, so a wooden frame inside the gap will serve two purposes-fixing for the board and stop the loose bricks dislodging. Yes I'll definitely install a vent. Is it true that these are now law?
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
