    Dismiss Notice
Is this in any way possible?!?
Discussion in 'Electrics UK' started by WabbitPoo, 5 Oct 2021.
  1. WabbitPoo
    WabbitPoo
    26 Feb 2005
    2,766
    Thanks Received:
    141
    Gwynedd
    Country:
    SWMBO wants the shower room fan to come on by means of a pull switch, but to go off again after a set time (maybe 15 mins) if you forget to do it manually after showering. Then, the next person comes along and wishes to switch on the fan does so as normal (in other words the switch has reverted to off automatically).
    If my description males any sense,, is it possible?!
  2. Sponsored Links
  3. EFLImpudence
    EFLImpudence
    7 Jul 2010
    37,452
    Thanks Received:
    4,199
    Retired to:
    Country:
    Portugal
    Yes - just a normal timer fan set to required time (there will be a maximum time) and a 'momentary/retractive' switch.
  4. WabbitPoo
    WabbitPoo
    26 Feb 2005
    2,766
    Thanks Received:
    141
    Gwynedd
    Country:
    I've never heard of a momentary/retractive switch - off to search for one....thanks
    so how would one be wired up to a fan, please?
  5. EFLImpudence
    EFLImpudence
    7 Jul 2010
    37,452
    Thanks Received:
    4,199
    Retired to:
    Country:
    Portugal
  6. 333rocky333
    333rocky333
    12 Jan 2008
    8,425
    Thanks Received:
    902
    Essex
    Country:
  7. rich8000uk
    rich8000uk
    7 Sep 2020
    3
    Thanks Received:
    Country:
    It would normally be run with the lighting circuit.
  8. EFLImpudence
    EFLImpudence
    7 Jul 2010
    37,452
    Thanks Received:
    4,199
    Retired to:
    Country:
    Portugal
  9. WabbitPoo
    WabbitPoo
    26 Feb 2005
    2,766
    Thanks Received:
    141
    Gwynedd
    Country:
    Thanks guys. so the fact that the fan will run on for some time is down to the fact that it has an internal run-on time built in (I presume they can be adjusted?)
    I think I get it now. Thank you all for your help
  10. Sponsored Links
  11. EFLImpudence
    EFLImpudence
    7 Jul 2010
    37,452
    Thanks Received:
    4,199
    Retired to:
    Country:
    Portugal
    Yes, integral timer.
    Yes you can adjust it up to its maximum - 30 minutes usually, I think.
    • Thanks Thanks x 1
  12. WabbitPoo
    WabbitPoo
    26 Feb 2005
    2,766
    Thanks Received:
    141
    Gwynedd
    Country:
    Would another (better?) Way to do it be to have a fan with a humidisat built into it, and have the green switched on all the time? That way as soon as someone stats a shower the fan will kick in and once the room is cleared enough it will just stop
  13. RandomGrinch
    RandomGrinch
    15 Jun 2021
    1,168
    Thanks Received:
    243
    Wales
    Country:
  14. JohnD
    JohnD
    15 Nov 2005
    74,224
    Thanks Received:
    4,287
    Crossgates, Europe
    Country:
    Cook Islands
    I don't find humidstat fans much good.
    If you walk into the bathroom to have a shower or use the WC, why wouldn't you want the fan to start at once?
  15. RandomGrinch
    RandomGrinch
    15 Jun 2021
    1,168
    Thanks Received:
    243
    Wales
    Country:
    I always start my humidistat fan with the lightswitch for showers etc.
    One of the benefit of the humidistat is when the humidity is generated elsewhere in the house, the fan then comes on and adds that bit of extra background ventilation.
    I also use a delay on timer. When using the WC in the middle of the night, it is best not to wake up the neighbours!
  16. JohnW2
    JohnW2
    28 Jan 2011
    48,626
    Thanks Received:
    3,189
    Buckinghamshire
    Country:
    Quite. If condensation on cold/coldish surfaces is the problem being addressed, then by the time the humidity has risen high enough to trigger a humidistat, it will be too late to stop at least some of the condensation occurring.
    Kind Regards, John
  17. JohnD
    JohnD
    15 Nov 2005
    74,224
    Thanks Received:
    4,287
    Crossgates, Europe
    Country:
    Cook Islands
    Do you need help in finding a modern good quality extractor with a ball-bearing motor and rubber mounts?
Loading...
Share This Page
