ISP
23 Nov 2003
I've got a mobile phone which I can use as a modem. I would like it to just dial a number and I'll be connected to the internet. I tried Tesco, NTL and Tiscali but they only work through BT land lines.
Does anyone know of an ISP which you can use through a mobile phone?
does it not use the gsm network? (no number required) I may be wrong though
I find it impossible to believe that NTL only works through a bt line, I suspect the problem is that you wish to use an unmetered package - this may be a problem because the ISP will require your phone number that you connect from - a landline. If you then try and connect on another number it wont let you, an unmetered pay as you go should work fine - bear in mind connection speed is crap off a mobile.
