This is a fairly typical (and amusing) Nutjob thread, where he asks for everyone's advice and then when they give it, manages to string it out to several pages of telling them that they're wrong...
He's not really looking for advice, he's looking for us all to tell him what a wonderful idea it is and how we all wished we'd thought of it first.
He'll make snide remarks about people lacking in "engineering feel", whereas, if he had the slightest scintilla of it himself, he'd have just bloody gone out, found the appropriate stiff bits of the vehicle structure, and done it, in less time than he's spent typing on here.
As it is, nobody with even an ounce of "engineering feel" would run the same engine oil for 10 years...
that said, My 2p-worth is as follows:
1. He's drawn what looks like a ventilated disc in his fag packet sketch. But mentions the back of the car. Not sure whether they're ventilated or not, but if they are, they're going to be at least 20mm thick and well able to support the weight of the rear corner of the car. Disc edges are usually a bit rusty, and if that's the case, a bit of wood on the jack pad will prevent any serious chipping of the edge of the disc.
2. He's talking about bolting a scrap disc, back-to-back, and jacking up on that, but its mounting face is unlikely to be the same thickness as the wheel, so he might find the wheel bolts bottom-out before they have actually successfully clamped the discs together tightly enough, which means the load will be just trying to bend the bolts.
3. There's no problem with either the hub or the wheel bearing not being able to take the load, because the car will have been designed to cope with cornering at close to 1G, fully-laden, and there will be a safety factor in the original design. However, the vertical loads will be applied through the tyre centre (give or take a bit for wheel offset), and by the time you've got two discs, back-to-back, the offset will be truly ridiculous and whatever prevents camber change, (probably the trailing arm bushes), will be given a really hard time as a result. Jacking on the actual disc edge would prevent this, but he's saying the stone shield is too close. Jacking up on the bell of the disc would probably be an option, though. (At least, in terms of being strong enough).
4. The biggest problem, however, is preventing the disc from rotating, and thus, falling off the jack. Maybe he has enough faith in his handbrake to prevent this, (and as it's not my car anyway, I can't say I particularly care), but that's for him to find out. The minute the force going up through the disc, moves ahead of, or behind a vertical line passing through the centre of the hub, it will try to rotate.
