HI
hope you guys can help, i have a jaguar/protherm 23k combi. recently there has been alot of water coming from overflow outlet on my boiler, and every know and again its been constantly running like a tap. then it stopped, its happened again today, so decided to check it out. Boiler was at 4.4 pressure when cold, so it was just the prv doing its job.The pressure i think was caused by the top up pipe being left slightly open (forgive my mind has gone blank silver tube that tops the boiler up) so i closed this fully and the pressure when back to normal.
However this morning, i woke up to F0 error, which manual says
loss of water
air lock on boiler
pressure sensor failure
So i opened the top up valve and corrected boiler back up to correct presure.
how the boiler seems to work fine, but i suspect it may be a faulty prv valve which isnt shutting 100% and there for would this be the cause of the loss of water?
thanks in advance for your help!
loss of water
air lock on boiler
