Hi - I tried to cut a kitchen worktop (mentioned in my previous post) with a Bosch GSR135 jigsaw fitted with a T101BRF blade, using a piece of wood clamped to the material as a guide, but ran into big problems...
The blade started deviating to the left about half-way through the cut (300mm), but, as the guide was resticting the machine itself from deviating, the blade collided with the metal guide on the jigsaw, producing sparks, knackering the blade and melting the plastic splinter guide.
After calling the Bosch helpdesk, I was left with the impression that jigsaws are not meant for straight cuts - is this true? I have to make a couple of very fine precise cuts in order to join two worktop sections together (40mm chipboard with hard, glossy plastic surface) and am wondering what's the best method - a circular saw? If so, any particular size & type of blade? Any suggestions would be much appreciated!
