    Dismiss Notice
Johnson & Starley Warm air Heating problem
Discussion in 'Plumbing and Central Heating' started by stevemus, 6 Jan 2013.
  1. stevemus
    stevemus
    6 Jan 2013
    2
    Thanks Received:
    Somerset
    Country:
    Hi
    Hoping someone out there is an expert with J&S System E-T warm air boilers.
    Last year ours stopped working, after some reading up I changed the temperature sensor and the main circuit board, which got it all working nicely again.
    In the last couple of weeks there has been a noisy clicking noise coming from the circuit board whenever the room thermostat turns it on or off.
    Its not all the time, maybe 30% of the time but I'm concerned its about to fail.
    It sounds like a relay switch flicking on and off.
    Does anyone have a good idea what's going on and if its an easy enough job to do myself?
    Like i said, I changed the circuit board myself so not afraid to have a go, even if I shouldn't?!
    many thanks
  2. Sponsored Links
  3. swbjackson
    swbjackson
    12 Dec 2008
    1,684
    Thanks Received:
    151
    Sussex
    Country:
    Warm air systems can be incredibly dangerous if not operating correctly and are not something that a DIYer should attempt any repairs on. Get a gas safe registered engineer in.
  4. stevemus
    stevemus
    6 Jan 2013
    2
    Thanks Received:
    Somerset
    Country:
    That's a bit of an over dramatic reply?!
    It's working ok except a relay flickering on and off briefly. Certainly not a gas safety issue IMO as the pilot light is always lit and the boiler fires up ok
  5. Bob100000
    Bob100000
    11 Dec 2015
    5
    Thanks Received:
    Country:
    My J32 ET has recently started getting the same problem. It sounds like a relay rapidly clicking before the fan kicks in. Did you get this resolved ok? What was the problem? I'm sure your experience would help the engineer when it comes to fixing mine. Thanks.
  6. muggles
    muggles
    28 Oct 2005
    13,334
    Thanks Received:
    3,073
    Daventry
    Country:
    Any engineer who is familiar with WAUs will be able to diagnose this problem easily without you telling him what was said on an Internet forum. You should, however, ensure that the Gas Safe engineer you contract has WAUs on his list of qualifications. Not many do.
  7. Bob100000
    Bob100000
    11 Dec 2015
    5
    Thanks Received:
    Country:
    Ok, so it's more for my benefit, not the engineer's. I've no intention of attempting to repair it myself, but I would still like to know if this is going to be a cheap or expensive repair, and whether it means replacing one cheap module or five expensive ones ;)
    And not being entirely dumb, I have checked the Gas Safe register for engineers qualified to repair warm air units.
  8. Sponsored Links
  9. geoff@cetltd
    geoff@cetltd
    5 Apr 2006
    1,076
    Thanks Received:
    11
    Country:
    It's capacitors on the pcb
    PLug and play replacement
    repaired one costs £50 ++ IIRC
    • Thanks Thanks x 2
  10. Bob100000
    Bob100000
    11 Dec 2015
    5
    Thanks Received:
    Country:
    Many thanks.
  11. Agile
    Agile
    26 Jun 2004
    64,017
    Thanks Received:
    4,591
    London
    Country:
    Or a new one perhaps £160.
    How are you Geoff?
    Tony
  12. bobmeade
    bobmeade
    29 Oct 2021
    Thanks Received:
    Country:
    Hi Geoff - do you remember which capacitors & how many you needed to change? my J32 is doing similar things!! I have a spare "system ET" board, that came out of a working J32 about 7 years ago - probably be a good idea to replace these Caps, before changing the board. I am very familiar with electronics & soldering....
    Thanks.
  13. Gasguru
    Gasguru
    9 Sep 2005
    12,442
    Thanks Received:
    3,307
    Sussex
    Country:
    Geoff hasn't posted for over 6 years....
Loading...
Share This Page
