Kaskade wet room trap fitting advice pls
Done the rounds of the plumbers merchants. None of them have anything even close. Kaskade doesn't supply fittings with it and don't stock any either (phoned and checked with them). I'm rather mystified how this product can be successfully installed, since presumably somebody out there buys it. None of the online videos about fitting give any clues either. They explain plenty about fitting the former etc, but skip over how to connect the trap to existing waste.
Still stuck, alas.
Standard 50mm solvent weld waste pipe in this country has an outside diameter of around 55mm which means a 50mm to 40mm multifit coupling will fit it, a decent merchants will stock something that will fit.
What Outside diameter is your waste?
