Hi For the past week 20 year old work horse boiler has started kettling noise ( medium pitch) boiler has had bi annual service and x100 topped up over 6 years ago when 3 port valve was replaced
1.Boiler potterton profile 100e 2.F&E tank 3.10 Radiators 4.HW storage cylinder with thermostat 5.fitted Water Softner 6.Twintech magnaclean (due to space constraint was fitted near the pump in loft cleaned annually) 7 boiler statis normally set 1.5 summer & between 3&4 in winter thanking in advance
Kindly note couple of days ago had air in hot water taps i had to drain the cylinder to get rid of the air
I had the same problems 6months ago!
Help/advise on kettling & air in hot water will be much appreciated
Ih
Ih
