I'm fitting a new kitchen, it will be 'U' shaped.
I've noticed in B&Q that I can use a 1000mm base unit has a corner cupboard if I use a corner post. But what I can't understand is, if I wanted to connect another cupboard up to the 1000mm to form the corner, how will the door fit.
The depth of a cupboard is 570mm, the other base is 1000mm wide, which means that the door section of the corner will be 430mm, but doors are 497mm wide.
I'm really confused on how these work. Any help will be much appreciated.
Jim
Jim
