I removed a baluster light out of my kitchen and replaced it with recess lights. All the lights in the kitchen operated off two seperate switches. All the lights off switch B work as planned, but switch A is giving me the blues. Switch a had one baluster light in the center of the kitchen. When I wired the lights nothing happened. So I bought a test kit. When the power is on the hot wire(black) is reading 119-121 volts, and 0 volts on the neutral(white). But when the power is off I get current readings from 70-117 from the neutral(white) wire... All the electrical was pre-existing, so what sould I do to fix this problem?
