    Dismiss Notice
Kitchen Problem
Discussion in 'Electrics UK' started by Bammer, 21 Nov 2005.
  1. Bammer
    Bammer
    21 Nov 2005
    46
    Thanks Received:
    Country:
    Hi-Have two gang socket in kitchen which is part of the downstairs loop. The heating engineer took a connection of this to create a FSU for the heating. As a result there are three wires going into each of the terminals of the two gang. Was trying to get fourth wire into each for the wall unit downlighters but finding it really hard. Can I tap into the FSU for that or do you think that soldering all four so that they easily go into the respective terminals on the two gang. Hope this makes sense
  2. Sponsored Links
  3. JohnD
    JohnD
    15 Nov 2005
    74,224
    Thanks Received:
    4,287
    Crossgates, Europe
    Country:
    Cook Islands
    That would mean taking two spurs off one socket. You should use a different socket. Or maybe you could extend from the lighting circuit.
  4. Albert
    Albert
    17 Feb 2004
    700
    Thanks Received:
    Country:
    I am not sure that I understand exactly the problem, but what I understand is that the guy added a FS to you ring which sounds ok to me, If you are trying to add a second one on the same two gang, it is not allowed, you can add another Spur in another socket and connect there what you need. you can add to a ring only one spur to each existing socket. if you wand more you need to add a fused spur and create a mini radial circuit. The fused spur should not excide 13A.
  5. Bammer
    Bammer
    21 Nov 2005
    46
    Thanks Received:
    Country:
    Hi and thanks for the replies. Have junction box one floor up. Can run FSU from this and create the supply I need or even run the cable for the wall unit lights direct from this. Think it may be the upstairs lighting loop. You can tell I am a newbie but trying to save costs. Any replies welcome
  6. JohnD
    JohnD
    15 Nov 2005
    74,224
    Thanks Received:
    4,287
    Crossgates, Europe
    Country:
    Cook Islands
    You will have someone along in a minute telling you about the special rules that apply, in a kitchen, to adding light fittings and switches, or socket oulets and spurs. If not, it's already posted here at great length. Look for the word "kitchen"
  7. Damocles
    Damocles
    14 Sep 2004
    1,301
    Thanks Received:
    Country:
    If you have located the lighting circuit in the ceiling, then you may not need a FSU. What does the light fitting say about supply fusing, and what is the lighting circuit rating? Chances are, if it is 6A then it will be fine already.
  8. Spark123
    Spark123
    2 Jun 2005
    14,841
    Thanks Received:
    474
    Cumbria
    Country:
    We need bald electrician to do this, Scotland ain't part p'd.
  9. Sponsored Links
  10. Bammer
    Bammer
    21 Nov 2005
    46
    Thanks Received:
    Country:
    Yeah Damocles it is 6A so does that mean can run t/e from the box direct to the wall unit and prob sorted? Wanted to install a switch so that can control whether I have the lights on or off
  11. JohnD
    JohnD
    15 Nov 2005
    74,224
    Thanks Received:
    4,287
    Crossgates, Europe
    Country:
    Cook Islands
    oh yes, the kingdom of Fife. Lucky.
  12. Bammer
    Bammer
    21 Nov 2005
    46
    Thanks Received:
    Country:
    JohnD_ Only two kingdoms Gods and Fife and I am blessed to stay in the latter lol
  13. Damocles
    Damocles
    14 Sep 2004
    1,301
    Thanks Received:
    Country:
    Yes, a switch is a good plan, but the fact you are starting from a low current supply means you do not need to fuse it down further.
  14. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    No - it's even worse...
  15. Bammer
    Bammer
    21 Nov 2005
    46
    Thanks Received:
    Country:
    Thanks for all the replies. Managed to figure a solution.
  16. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
